AVI movie file with line tracking
Hello, I am trying to make an AVI movie file for a line tracking station. When I try to create the AVI and I start the conveyor, the robot seems to fall behind with tracking the part. Has anyone else tried this, and if so, any suggestions to make this work properly. I have also tried this using SnagIt. The same thing happens with this too.
Thanks,
Bob
There are a couple of settings in the avi recorder that you can play with (avi capture options button)
The settings I use in most of the cases is
- Capture Frame Rate = 10
- Playback Frame Rate = 30Per Svensson
Company Specialist
Hello Bob,
In the Conveyor Setup there is a setting called "Compensation Distance". This setting can you use if the robot miss the targets when you run a simulation with a conveyor.
ABB Robotics0
- 858 RAPID Programming
