Convert MoveJ to MoveL
Hardikez
When I convert a MoveJ to a Move L, the line between to points is changed to yellow to show that it is now a liniar move, but if I convert back to a MoveJ the collour between the 2 points is still yellow.shouldent i be blue again.
Kent Zibrandtsen
Dept manager robot welding
Kez@hardi-international.com
this is also the same in RS.5.10
Kent Zibrandtsen
Kez@hardi-international.com0
- 359 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 30 AppStudio
