how to connect to S4 system M98
memphiss
hello, does anyone know how to connect PC to S4 controller (M98),except Floopy disk?
I know that backup made to floopy disk can be opened by PC Windows .
But beside this way,Is there some network method (like S4C+ and IRC5) or serial port connection method, for
us to backup/load program file on S4 controller?
If your controller doesn't have the RAP/FactoryWare options or Ethernet services then there are no other options.
Russell Drown0 -
As stated, if you do have for instance ethernet services, just use a crossed ethernet cable and connect to the controller using any ftp client. The connection address is then 192.168.125.1 for the service port.0
Thank you Russell and aNoRSWE. Unfortunely I checked and found I did not have option of RAP/FactoryWare options or Ethernet services. I have to give up and turn back to floopy disk.
- 304 PowerPacs
- 354 IRC5
- 850 RAPID Programming
- 26 AppStudio
