Variable robtarget name
Is it possible to define a variable robtarget name and use it?
Something like:
VAR STRING targetname;
VAR robtarget target1:=[[0,0,0],[...etc
VAR robtarget target2:=[[0,0,0],[...etc
VAR robtarget target100:=[[0,0,0],[...etc
VAR num x{100}:={0,0,0,0,....,0};
FOR i FROM 1 TO 100 DO
  targetname:="target"+NumToStr(i,0);
  x{i}:=targetname.trans.x+10;
ENDFOR
  • x{i}:=targetname.trans.x+10;
    in your code targetname is a string varibale, can't use targetname.trans.x
    where do u use this program?  maybe u can find other way to program.
    Peter_ABB2008-4-16 15:54:45
    Peter
  • Sorry, that code won't be possible, late binding is only valid for procedure calls and such. You'd like something like .Net's 'FOREACH (Robtarget rt in ...)' :)
    Are you just trying to add 10mm to the x value of each target in the array? Just put all the targets in the array to begin with, and then go:
    VAR num x{100}:=[[0,0,0,0,....,0] ... ];
    FOR i FROM 1 TO Dim(x,1) DO
      x{i}.trans.x:=x{i}.trans.x+10;
    ENDFOR
  • hi,
    with the option advanced rapid you can use the instruction getdataval.
    Then your programm can look so:
    VAR robtarget targetname;
      GetDataVal "target"+NumToStr(i,0),targetname;
    ENDFOR
    Thilbi2008-6-17 11:21:48
  • Thats a nice solution Thilbi, didn't think of that!
    Just a note, as of 2008, Advanced Rapid is included in the standard robotware.
    aNoRSWE2008-6-18 9:20:2
