movement along axis
HI,
I have a path along the x and z axis. From my observation, the robot will move diagonally along the resultant of x and z axis.
Can i make it move along the z axis first and then move along the x axis? or maybe any other idea?
(I want to use it in interrupt routine. if interrupt was occur, robot must to back in home position, but it must move along the z axis first, because there are many things in the front of robot -> in x axis. if it moves diagonally, it can be a collision)
orange line: the movement of ABB robot
blue line : the movement that i need
thanks a lot
regards,
carmila
carmila2008-6-25 4:33:34
Hmm... I'm not sure I got the problem right, but maybe something like this could be used as an idea ..?
TRAP myTrap
VAR robtarget pTmp;
StopMove;
WaitTimeInPos, 0.1;
pTmp:=CRobT(Tool:=tMyToolWObj:=woMyWObj);
ClearPath;
nMyZValue:=pMyHomePos.trans.z;
StartMove;
MoveL Offs(pTmp,0,0,nMyZValue),v200,fine,tMyToolWObj:=woMyWObj;
MoveL Offs(pMyHomePos,0,0,0),v100,fine, ... ;
ENDTRAP
aNoRSWE2008-6-27 7:55:430 -
HI, is this solution worked , may be your robot move uptill end limit in some case. Pl do like this ,offset in z=home.z-ptem.z , may be. pl try
br/pankaj
hi, AnorSWE and Pankaj
thanks for your advices, it very helpfull. For AnorSWE, there is some miss syntax, the START MOVE. I have try your advice and the robot won't move. When I add the START MOVE before the MOVEL OFFS, it works (by the way, i'm very thankful to you
For Pankaj, I will try your advice. Thank you so much
regards,
carmila
indah carmila0 -
That's right, really sorry about that!
I have edited my previous post.
Good Luck!
Andreas
- 304 PowerPacs
- 354 IRC5
- 850 RAPID Programming
- 26 AppStudio
