Wanted: IRB6400/2.4-150 for RS5.10
Hello
I need to find the robotstudio library for IRB6400/2.4 -150 robot. I'm using Robotstudio 5.10.
Is there somebody how can help me with this?
/Hans
/Hans
Hi Hans,
Since the IRB6400 isn't supported by IRC5 it is not supported by RobotStudio 5.x.
You can import the attached RobotStudio-S4 library into RS 5.10, but you won't be able to setup a controller for it.
2008-07-03_133037_IRB6400_S4.zip
regards, Johannes
Johannes Weiman2008-7-3 13:34:37Johannes Weiman
ABB Robotics0
- 338 IRC5
- 67 OmniCore
- 832 RAPID Programming
- 14 AppStudio
