Messaging Namespace PC_SDK
I was wondering when the eventhandlers for the Messaging Namespace for PC_SDK are released.
F.Roos
  • Hi,
    I wonder what information you are referring to? As far as I know, there has been no intention to add any events to the Messaging namespace. Are you already using IPC messaging?
    Ingela Brorsson
    ABB Robotics, Sweden
  • Hi,
    In the controller TASK it is possible to connect a trap routine when a message is received in RMQ. But when you sent messages the other direction. That is from Controller to windows Application. I didn't found a solution with current namespace to handle when a message is received in Queue.
    That's where I was referring to. The Eventhandlers when a message is received in Queue.
    The .Net system.messaging has eventhandlers when messages is completely received? I can't use these, because then there is a mismatch between ABB.Robotics.controllers.messaging and system.messaging.
    Is it possible to create a handler when a new messages from controller is received in Queue?
    F. Roos
  • Hola,
    IPC messaging was released in 5.10.
    There isn't an event handler to be notified whenever a message is in the queue. Eventhough, you can create a class which fires an event whenever a message is received: just create a thread which is constantly trying to receive a message:
    private static void ServerStart()<?:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
        IpcMessage message;
        IpcReturnType ret;
        try
           // Assume that _ipcSender is created before
            while (_ipcSender != null)
                 message = new IpcMessage(Ipc.MaxMessageSize);
               // Try to get a messsage, times out after 50mm
                 ret = _ipcSender.Receive(50, message);
                 if (ret == IpcReturnType.OK)
                     // Process the message
        catch (Exception e)
            MessageBox.Show(e.ToString());
    Saludos/Carlos
    Carlos Martinez
    ABB
