Messaging Namespace PC_SDK
I was wondering when the eventhandlers for the Messaging Namespace for PC_SDK are released.
F.Roos
I wonder what information you are referring to? As far as I know, there has been no intention to add any events to the Messaging namespace. Are you already using IPC messaging?
Ingela Brorsson
ABB Robotics, Sweden0 -
In the controller TASK it is possible to connect a trap routine when a message is received in RMQ. But when you sent messages the other direction. That is from Controller to windows Application. I didn't found a solution with current namespace to handle when a message is received in Queue.
That's where I was referring to. The Eventhandlers when a message is received in Queue.
The .Net system.messaging has eventhandlers when messages is completely received? I can't use these, because then there is a mismatch between ABB.Robotics.controllers.messaging and system.messaging.
Is it possible to create a handler when a new messages from controller is received in Queue?
F. Roos
Hola,
IPC messaging was released in 5.10.
There isn't an event handler to be notified whenever a message is in the queue. Eventhough, you can create a class which fires an event whenever a message is received: just create a thread which is constantly trying to receive a message:
private static void ServerStart()<?:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
IpcMessage message;
IpcReturnType ret;
try
// Assume that _ipcSender is created beforewhile (_ipcSender != null)
message = new IpcMessage(Ipc.MaxMessageSize);
// Try to get a messsage, times out after 50mm
ret = _ipcSender.Receive(50, message);
if (ret == IpcReturnType.OK)
// Process the message
catch (Exception e)
MessageBox.Show(e.ToString());
Saludos/Carlos
Carlos Martinez
ABB0
- 341 IRC5
- 68 OmniCore
- 839 RAPID Programming
- 18 AppStudio
