value out of range?
Hello all,
I have a "large" structure that has:
- 15 strings
- 13 nums
- 7 bools
- 1 wobjdata
When I try to modify the value of (for example) one of the nums inside from the flex pendant, I can modify it, but when I press OK nothing happens in the robot (the value is still the old one).
If I try it in the RobotStudio software it tells me that the value is out of range, but it is not possible as the original value is 31 and I try to change it to 2. (And I've not set any kind of limit anywhere).
Any idea on why is do this happening?
As always thank you in advance.
Do you have an example of your structure
Regards
Knud Erik Lindberg
Jorgensen Engineering0 -
Here we go:
PERS strctTest strTest{2} := [["101",1,3,3,20,3,3,1,321,180,148.087,5,40,3,FALSE,FALSE,FALSE,FALSE,FALSE,["?11","?12","?13","?14",[FALSE,TRUE,"",[[835.41,-57.918,626.073],[0.004456,-0.000362,-0.001447,-0.999989]],[[0,0,0],[1,0,0,0]]]],["CX11","CX12","CX13","","","CX16","CX17","",""]],
["201",1,3,3,20,1,1,1,321,180,148.087,5,40,3,FALSE,FALSE,FAL SE,FALSE,FALSE,["?21","?22","?23","?24", [FALSE,TRUE,"",[[835.41,-57.918,626.073],[0.004456,-0.000362,-0.001447,-0.999989]],[[0,0,0],[1,0,0,0]]]],["CX21","CX22","CX23","","","CX26","CX27","",""]]];Thank you in advance...
Do you also have the record declaration
Regards
Knud Erik Lindberg
Here you have it:
RECORD strctTest
string s1;
num n0;
num n1;
num n2;
num n3;
num n4;
num n5;
num n6;
num n7;
num n8;
num n9;
num n10;
num n11;
num n12;
bool b0;
bool b1;
bool b2;
bool b3;
bool b4;
strctPP1 strPP1;
strctPP2 strPP2;
ENDRECORDRECORD strctPP1
string s1;
string s2;
string s3;
string s4;
string s5;
string s6;
string s7;
string s8;
string s9;
ENDRECORDRECORD strctPP2
string s1;
string s2;
string s3;
string s4;
wobjdata wo1;
ENDRECORDWhat do you think?
Joan2008-7-31 15:16:130
- 303 PowerPacs
- 353 IRC5
- 849 RAPID Programming
- 24 AppStudio
