Adjusting tcp, robot drifts
Hello all, i hope someone can help me with this problem as i've been puzzeling over it a few days now. i'm working on a material handeling application, i've got varying sized sheets coming down a conveyor we are measureing and squaring them up, then the robot (irb7600) must pick thim up and run the edge of the sheet along a glue dispenser. there is an infinate possibility for sizes of sheets so i was trying to write one program to handle all the sizes by adjusting the tcp.trans.y value, and from my experience with other robots this should work. but say i add 100mm to trans.y and move to a previously taught robtarget the robot move 95mm away in y and 10mm away in x. and if i add 300mm the robot moves 285mm and 30mm.
the tcp orients and jogs nicely (aligned) in all directions.
i tried to do a stationary tool and hold workobject but with the same results.
the only thing i can think of is that my tool has a 14.9deg rotation because the bolt holes did not align with the robot flange.
Any help would be much appreciated.
Russ
It seems that you define your tool only by adding data value.
Why not teach it by 6-point method?
have you tried defining a work object at the glue dispenser? you should define the y axis of the work object u-frame along the direction of the size change. Then adjust the workobject o-frame to acommedate the different sheet sizes. wobj.oframe.trans.y.
You may also be able use the offset function on your Move instructions instead . MoveL Offs(p2, 0, nSizeOffs, 0), v1000, z1, tool1;
BR
Jim
- 367 IRC5
- 858 RAPID Programming
