Disable a robot in automatic mode?
Joan
Hello all,
In order to make tests, I'd love to disable a robot in automatic mode, I've not been able to do it, do you know if it is possible?
As always thank you in advance...
I'm not sure if I understand your question. However, you can press the Emergency Stop button from the RobotStudio Control Panel or the Virtual FlexPendant during simulation in Auto mode.
[QUOTE=Joan]
Hello all,
[/QUOTE]
I think you can attempt to reduce the speed to 0%
In Simulation Setup you can uncheck the controller or task you want to disable in the simulation.
Kind regards,
Henrik
ABB0
- 365 IRC5
- 38 AppStudio
