Disable a robot in automatic mode?
Hello all,
In order to make tests, I'd love to disable a robot in automatic mode, I've not been able to do it, do you know if it is possible?
As always thank you in advance...
  • Hi,
    I'm not sure if I understand your question. However, you can press the Emergency Stop button from the RobotStudio Control Panel or the Virtual FlexPendant during simulation in Auto mode.
    ABB
  • [QUOTE=Joan]
    Hello all,
    [/QUOTE]
    I think you can attempt to reduce the speed to 0%
  • Hi,
    In Simulation Setup you can uncheck the controller or task you want to disable in the simulation.
    Kind regards,
    Henrik
    ABB
