hide paths and targets
plowguy
Is there a way to "permanently" hide paths and targets? I hide them via the VIEW pull down menu and they reappear when the path is run.
If the "Visible" property does not work the way you want, I suggest you simply delete the targets and paths from the station. The simulation will use the RAPID program anyway. If you want them back you can sync them to the station again. Be careful with the workobjects though, if you have attached them to any geometry. It may be safer to keep the workobjects not to lose data.
If you use ArcWeld PowerPac you should not delete the targets, since AWPP makes use a so-called reference coordinate system to offset the targets. This information is not reflected in RAPID and lost if the RS targets are deleted.
ABB0
- 359 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 30 AppStudio
