Add-in for RS 5.07
AlexLu
My RS 5.07 does not offer RS API help. It is grey in the menu.
Need help on how to build Add-in in RS 5.07. What's the difference from RS 3.2?
Hi Alex.
Documentation of the RobotStudio API will be included in the next release (5.08). For now, I can provide you with some auto-generated documentation. Note that it is unsupported, incomplete and possibly incorrect!
2006-07-14_110219_APIDoc.zip
The RobotStudio 5.x API is .NET based and you need Visual Studio 2005 to build an addin. Typically you would program in C# or VB.NET. The requirements for an addin are very simple:
1) It must contain a public, static and parameterless method called AddinMain
2) The DLL must be placed in the RobotStudioBinAddins directory
To use the RS API you need to reference the ABB.Robotics.*.dll assemblies. These are:
ABB.Robotics.Math - Vector and matrix math
ABB.Robotics.RobotStudio - General and top-level (e.g. non-Station specific) classes
ABB.Robotics.RobotStudio.Environment - For manipulating the GUI, e.g. adding menus and buttons etc.
ABB.Robotics.RobotStudio.Stations - For manipulating stations and their contents
ABB.Robotics.RobotStudio.Stations.Forms - GUI controls used by RS
Below is an example of a basic addin written in C#:
using System;
using ABB.Robotics.RobotStudio;
using ABB.Robotics.RobotStudio.Environment;
using ABB.Robotics.RobotStudio.Stations;
using System.Windows.Forms;
namespace MyAddin
public class MyAddin
// This method is called when RS starts
public static void AddinMain()
// Create a new command button
CommandBarButton button = new CommandBarButton("HelloMyAddin", "Hello MyAddin!");
// Add the button to the "Tools" menu
// The IDs of predefined menus and commands are found in "RobotStudioIDSummary.html"
CommandBarPopup.FromID("MenuTools").Controls.Add(button);
// Connect the command events
button.UpdateCommandUI += new UpdateCommandUIEventHandler(button_UpdateCommandUI);
button.ExecuteCommand += new ExecuteCommandEventHandler(button_ExecuteCommand);
static void button_UpdateCommandUI(object sender, UpdateCommandUIEventArgs e)
// Enable the button
e.Enabled = true;
static void button_ExecuteCommand(object sender, ExecuteCommandEventArgs e)
// Do something
MessageBox.Show("Hello MyAddin!");
regards,
Johannes
Johannes Weiman2006-7-14 12:34:40Johannes Weiman
I am trying to use this to build an addin that will update positions of targets.
When i try to compile
CommandBarButton buttonGantryUpdate = new CommandBarButton("GantryUpdate", "Gantry Update");
buttonGantryUpdate.UpdateCommandUI += new UpdateCommandUIEventHandler(buttonGantryUpdate_UpdateCommand UI);
buttonGantryUpdate.ExecuteCommand += new ExecuteCommandEventHandler(buttonGantryUpdate_ExecuteCommand );
i get
An Object reference is required for the nostatic field, method or property. I am using all the suggested ABB.Robotics items and have referenced the dll files in the SDK directory
Any ideas?
[QUOTE=mattdavis]
[/QUOTE]Hi,
There is a white space in the argumentlist between "UpdateCommand" and "UI". Is that expected?
thats a weirdness of the forum i think. I cut and paste that from my code and theres no space in the code. Thanks for the suggestion and damm good spotting.
Is buttonGantryUpdate_UpdateCommandUI and buttonGantryUpdate_ExecuteCommand static? Try to make them static, and see if that works.
yes that works.
Thanks alot for that, im confused as to why it works but.. it does.
This discussion has been closed.
