Error message on screen recocording
kuv-vokl
i get an error when i try to perform screen recording with windows media recorder (see screenshot and error report)
Can anybody help me ?
Many thanks
Klaus
Klaus Vogel
Kühne+Vogel Sondermaschinen GmbH
Hi Klaus,
This error (in english: "Not enough storage space for this procedure") is caused due to a limitation in RS when trying to use the screen recorder on heavy simulations (approx. when station >100MB). Most likely, it will work fine if you try on a less heavy station. However, as a workaround in this case, I recommend you to use a third party product instead (for example Camtasia). I have reported this problem to the dev. team so hopefully we will soon see a solution in an upcoming release.
Anders Jahnberg, ABB Robotics
Anders Jahnberg
Hi Klaus!
I got the same Problem in my station. You can also use Microsoft Media Encoder with Option "Screenrecording". There you can select the part of the screen you want to record.
By the way: I suppose it's the same RS does but this way it works.
