EIO error! Please help me quick!
TRiXTeR
Hi!
I have made a new EIO.cfg file but i have made it from the old one and when i load it and restart the robot i get the message "error startup synchronize -1" but i cant see anything wrong with the new EIO.
The system is S4cPlus
//Fredrik Johansson
//Fredrik Johansson
could u send your eio.cfg file
Erdem Karaçeper0 -
What is the difference between your new eio.cfg and old eio.cfg? What did you do,(ex: add an input or output)? Have you done any physical connections in the controller?Only God Can Judge Me0
Check your SMB cable.Lee Justice0
I think i have solved the problem!
If this doesnt work i will send the EIO.cfg
Thank!
//Fredrik Johansson
- 304 PowerPacs
- 354 IRC5
- 850 RAPID Programming
- 26 AppStudio
