EIO error! Please help me quick!
Hi!
I have made a new EIO.cfg file but i have made it from the old one and when i load it and restart the robot i get the message "error startup synchronize -1" but i cant see anything wrong with the new EIO.
The system is S4cPlus
//Fredrik Johansson
  • could u send your eio.cfg file
    Erdem Karaçeper
  • What is the difference between your new eio.cfg and old eio.cfg? What did you do,(ex: add an input or output)? Have you done any physical connections in the controller?
    Only God Can Judge Me
  • Check your SMB cable.
    Lee Justice
  • I think i have solved the problem!
    If this doesnt work i will send the EIO.cfg
    Thank!
    //Fredrik Johansson
