LocalDirectory persistent?
I'm creating a file (App.Log) int the LocalDirectory (with GetFile()).
In the Virtual FP i can see this file in /INTERNAL, but in real FP i cant see it.
In real FP it should be in /TEMP, but not.
Question: Is the LocalDirectoy persistent or is volatile?
Marcos Foglino
Hola Marcos,
This is a property that you can get or set for the FileSystem instance that you have for each Controller instance. You can set some predefined values. This is explained in the FP User's guide:
Environment variables: "When specifying file system paths you can use environment variables to denote the HOME, system, backup and temp directories of the currently used system. When an application uses "(BACKUP)$" it is internally interpreted as the path to the backup directory of the current system. The other environment variables are: HOME, TEMP and SYSTEM. "
Saludos/Carlos
Carlos Martinez
Carlos, thanks for you information.
But my question is:
Because, i cant find the App.log in any folder in the real FP.
thanks
Marcos
I think it gets initialized to the same value each time the FP starts, it doesn't change unless you explicitly change it. You can use the remote file viewer to look at the contents of the FP ramdisk. Note that the file itself will be gone as soon as the FP is restarted because it is not possible to store files on the device.Russell Drown0
Sorry ... you were referring to the LocalDirectory, not the Remote one. If I remember correctly, the value of thar property is only valid for that instance. If you create a new Controller class, then the default value should be '/Temp/'.
Have you tried to set the Local Directory just after getting the FileSystem, so it guaranteed that you are working in this FP directory.
Carlos
Carlos Martinez
Thanks, Carlos and Russ.
So, i can create a file on real FP?
I am using Log4net to log application actions.
Log4net create a file (App.log). In the virtual FP, it works.
It creates the file /INTERNAL/App.log.
But in the real FP, not works.
thanks.
Marcos Foglino
You can create a temporary file on the FP, it will be destroyed the next time the FP restarts.Russell Drown0
Hi Marcos,
Is this a shareware that I can download it and try. Just to check if the problem is in the Fp, or the application is not compatilble with the Operatyng System
BR.Carlos
Carlos Martinez
ABB0
- 338 IRC5
- 67 OmniCore
- 832 RAPID Programming
- 14 AppStudio
