SpeedData
Hi.
How can i read/write Speeddata. Cant find the name space.
Best regards Klaus
Klaus Soenderhegn
www.cadalysator.dk
You use GetRapidData to get an instance of RapidData = to variable you want, then you cast it to the RapidType you want, in your case SpeedData, then you work with the elements of the SpeedData type, then write the new value back to the controller. Here is a sample from the help:
private void IncXOrientation(Conroller c)
try
// Create RapidData instance to Rapid array
RapidData rdRobtarget = c.Rapid.GetRapidData("T_ROB1","MyModule","rt_array");// Values are added in reverse order
for (int i = 5;i > 0;i--)
// Get value of item
RobTarget rtValue = (RobTarget) rdRobtarget.ReadItem(i);// Increase X
rtValue.Trans.X += 1;// Apply new value to Rapid data in controller
rdRobtarget.WriteItem(rtValue,i);
catch (GeneralException ee)
// TODO: Add error handling
catch (System.Exception ee)
finally
if (rdRobtarget != null)
rdRobtarget.Dispose();
}Russell Drown0
