FlexPendant Start View Problem
trauto
I keep getting the following error when opening the virtual flexpandant, Programming mode won't display any code, nor would the robotstudio online, it will list all the modeules and even routines in the robot View but won't display any code. any help is greatly appreciated:
Description
Error when creating object of type
ABB.Robotics.Tps.Production.TpsViewProductionWnd(TpsViewProd uctionWnd.dll)
Data for this message is not saved in any robot controller event log.
If acknoledged the message will be removed.
Additional Info:
Message:0xc004ffff
Error Code:(0xc004ffff)
ERROR:.
apid.c[5067]:org_code:-3021 new_code:0xc004ffff;
RobRapidModuleImpl.cpp[387];AdaptRapidModule.cpp[267];
ABB.Robotics.GeneralException at GetTextProperties in Dcl.rapid/AdaptModule
at ABB.Robotics.Dcl.ExceptionHelp.ReThrowException(String objStr, String method, Exception exception, String additionalinfo)
at ABB.Robotics.Dcl.ExceptionHelp.GenerateException(String objStr, String method, Exception exception, String additionalinfo)
at ABB.Robotics.Dcl.ExceptionHelp.GenerateException(Object obj, String method, Exception exception, String additionalinfo)
at ABB.Robotics.WinCore.TPAppFwk.SiteServices.ABB.Robotics.WinC ore.TPAppFwk.Base.ITafSite.LanchTPAppControl(TacLaunchInfo&a mp; launchInfo, TacContainerContext& containerContext)
at ABB.Robotics.Tps.Controls.TpsExecute._launchAppOnOpModeChang e()
Description
Additional Info:
Message:0xc004ffff
ERROR:.
What version of RS and RW are you using?
If you put the controller into manual and open the Virtual FlexPendant, does that open OK?
If so, what happens when you run the check program function in the RAPID editor...is there a syntax error? If there is, try fixing the syntax error then re-open the Production Window.
Russell Drown0 -
Sorry for not following up with it earlier.
I am using RS 5.10.2400.147 and RW 5.10.0147.
I was able to get the Virtual FlexPendant to start properly when switching to manual mode first. The problem seems to go away after a subsequent restart of RS. I am not sure what had triggered the problem in the first place. There is no syntex error in the code.
Thanks for the help!
- 365 IRC5
- 38 AppStudio
