API: Delete RsToolData
Matthias
Hi!
I want to delete a RsToolData from my Task:
[code]
if (mechRobot.Task.DataDeclarations.Contains(myTool.Name))
mechRobot.Task.DataDeclarations..Remove(myTool);
[/code]
This is the error I get:
System.ArgumentException: Object must have same parent.
in
ABB.Robotics.RobotStudio.Stations.RsDataDeclarationCollection.Remove(RsDataDeclaration dataDeclaration)
in RSAddinTest.Class1.loadScene(Object sender, ExecuteCommandEventArgs e)
Can anyone please tell me why this does not work?
Best Regards, Matthias
[code]
[/code]
in
This may give you some help how to delete RsToolData
public void Macro_DelTool()
Station stn = Project.ActiveProject as Station;
if (stn == null) return;
if (stn.ActiveTask.DataDeclarations.Contains("myNewTool"))
RsDataDeclaration tool = stn.ActiveTask.DataDeclarations["myNewTool"];
stn.ActiveTask.DataDeclarations.Remove(tool);
}Per Svensson
Consat Engineering0 -
And the reason is that you have RsToolData in the remove method and not a RsDataDeclarationPer Svensson
Consat Engineering0
- 361 IRC5
- 78 OmniCore
- 853 RAPID Programming
- 30 AppStudio
