Change Path color
Petri
Is It possible set path color in RS 5.11?
BR
Petri
Yes, you can set the path color for each individual move instruction.
Select the move instructions and choose "Set Color" in the context menu:
regards,
Johannes
Johannes Weiman
Ok, thanks. Figured it out just my self too.
If there is action instruction middle then multible selection does not work.
BRPetri0
