Rebuild Errors after RAB5.11 upgrade
The following errors appeared upon rebuilding a C#/PCSDK application after installing RAB5.11. The previous version was RAB5.10, and it built without error prior to the upgrade to 5.11.
C:WINDOWSMicrosoft.NETFrameworkv2.0.50727Microsoft.Common.targets : warning MSB3293: Could not resolve dependent COM reference "8a61946c-5307-40ce-87bb-4363fb62618b" version 1.0.
AxUICONTROLLERINFOLib : error MSB3290: Failed to create the wrapper assembly for type library "AxUICONTROLLERINFOLib". Exception of type 'Microsoft.Build.Tasks.ComReferenceResolutionException' was thrown.
C:WINDOWSMicrosoft.NETFrameworkv2.0.50727Microsoft.Common.targets : warning MSB3293: Could not resolve dependent COM reference "d020c503-6e8a-4361-b1ee-c7c761016a53" version 1.0.
AxUICONTROLLERSYSTEMLib : error MSB3290: Failed to create the wrapper assembly for type library "AxUICONTROLLERSYSTEMLib". Exception of type 'Microsoft.Build.Tasks.ComReferenceResolutionException' was thrown.
... and I can't debug it either because...QUOTE. "The dcoument cannot be opened. It has been renamed, deleted or moved."
All my project references still point to the RAB5.10 PCSDK directory, so supposedly there shouldn't be any change in the build of this application....
Let me know of a place to start looking for a solution to this please.
Mike Kegley
Hm, I don't know, but as the COM references of the warnings:
COM reference "8a61946c-5307-40ce-87bb-4363fb62618b" and
belong to RobotStudio I would uninstall RobotStudio.Best regards,
Ingela Brorsson
ABB Robotics, Sweden0
