Small cosmetic note.
Tedenljung
Hello!
This is not a big issue just cosmetic, when you open FlexPendantViewer you see label1 instead of a time.
Is this Forum the right place to report suggestions/bugs/improvements for RS?
Or is there an other way, ex. feedback@abb.com...???
Hi,Thank you for bringing this problem to our attention.The Forum is one way to report problems. To report it to your local ABB representative that can file a defect report is another. The latter will ensure the problem gets the proper attention.Henrik Berlin
Maybe there should be a Topic as Sicked with label "Suggestion/Bug/improvements"in every Category. Where all drop there notices? Today topics will be spread over time and it's not so easy to see if some other has reported!
The best thing for this kind of feedback is a tracking system (my opinion)
http://trac.edgewall.org/ is a example.
- 337 IRC5
- 67 OmniCore
- 831 RAPID Programming
- 14 AppStudio
