Reverse Weld Dirctions [ArcWelding PowerPac]
I was told that it is possible to reverse the weld direction for a MultiPass weld and/or a weld programmed in RobotStudio....
(i.e.: 1st weld goes from L-R, the 2nd I want to go from R-L, and 3rd L-R, so on and so forth...)
Is this true?
If yes, how do I do it???
Dory England
Ridewell Corp.
Springfield, MO, USA
You are always too young to be old, but you are never too old to be young...
  • Hello,
    Earlier ABB used AWC with multipass and now MultiPass in Weldguide. You can run the same code in the virtual controller.
    BR / Henrik
  • In your multidata you define the direction you require.
  • I am sorry for the ignorance...
    But, Istill am not sure on how to reverse the direction of a "Multipass" weld using the "ArcStoreOn/Off" feature...
    I know that I can just teach the different directions, but is it possible to do this via ArcStoreOn/Off of in RobotStudio?
    Thank you for your patience...
    Dory England
    Ridewell Corp.
    Dory England
    Ridewell Corp.
  • webwiz/2637/Multipass_Example.zip
    You can do it using the ArcRepl Instruction defining the direction in the multidata. PLease find attached a zip file that may explain it. If not let me know and I'll try to explain better. There is also a weldguide manual that ABB produce that may help.
  • ClapClapClap
    Outstanding!!!
    I have overlooked this time and time again....
    I will try what you sent me...
    No news will be good news...
    I appreciate your help...
    Thanks again,
    Dory England
    Ridewell Corp.
    Dory England
    Ridewell Corp.
