screen image cut
I am having issues with the images on the screen being "cut" as I zoom in on the image. (see below) My "options" setting are all "default".  Many times I can't zoom in close enough to properly place welds.  This is something that just started today.  What can I do to remedy?  Thanks.
<?: prefix = o ns = "urn:schemas-microsoft-com:office:office" />image
  • Hi
    There are some settings related to graphics performance and you can find it in
    RobotStudio OptionsGraphicsPerformance that may help you solve the issue
    Per Svensson
    Consat Engineering
  • Try to "Set View Center" on the point you want to zoom in to.
    regards,
    Johannes
    Johannes Weiman
    ABB Robotics
  • I have tried all the various settings in "options" and "set view point" but nothing seems to fix the issue entirely. ??
  • Hello,
    You probably did not configure the geometry you imported for the gun to render on both sides of the surface. See the attached doc which shows the difference of importing without modeling both sides and with modeling both sides
    BR
    Jim Proulx
