Virtual Robot - RESOLVED [WebWare SDK]
Well, I got some more problems:
The documentation says I should use Virtual Robot Controler for Testing my apps.
If I try, I got the following error:
"the current robot has not been selected. Run the Preferences application to select the current robot"
I do not know, where to find this app.
Robots used: S4, S4C+, IRC5 with Ethernet Option enabled (robots are pingable)
Dev: VB6 with SDK3.2 and Interlink 3 installed
Dest.: PC with VB6-runtimes and installation of our app + Interlink 4
thx
mathric38400,319201388901000111
If you don't have an icon for the "Virtual Robot Browser", please try to browse to "C:Program FilesCommon FilesABB AutomationBin" and run "Prefer.exe".
Once the program is started, you can select "Set current robot" on the virtual robot you want to use.
AndersD38399,5971412037
______________________________
Anders Dannberg
ABB Automation Technologies
Support Engineer0
