5.11 Does not recover from failed save
Kevin
When Save Station fails due to a temporary network error, the save progress bar continues to run and it is not possible to continue working. A further attempt at saving results in two progress bars running.
Here is the log file:
webwiz/40/RobotStudio_2678_081103_103959.zip
Regards,
Kevin
Regards,
Kevin
Hi Kevin,Thank you for the log file. We will look into it.Best regards,
ABB Robotics0
- 337 IRC5
- 67 OmniCore
- 831 RAPID Programming
- 14 AppStudio
