Binding-source occurs unexpected error
chaos
Hello all together,
I have a really big problem with the binding-sources.
If I am using a binding-source (signal or data) it occurs often an unexpected error of the controller and the controller has to be switched off, in the reason of that nothing can be done anymore with the robot. I tried to handle this problem with an Error-Handler but it does not work.
Has somebody of you experience with it?
I would be appreciated if somebody could help in this case.
kindly regards
kindly regards
Hello,Sounds strange, you must be doing something wrong. Have you followed the description of the User's Guide (Using the FlexPendant SDK - Building the user interface - DataBinding of RAPID data and IO signals )?Best regards,
Ingela Brorsson
ABB Robotics, Sweden0 -
Hi,Can you provide a simple code that which shows what you are doing? and also the RAB version?ThanksCarlosCarlos Martinez
I found the mistake in the source code - i connected the signal binding on a label.tag and not on label.text - it seems if it is connected to the tag, that this connection is instabil.
I am using RAB 5.11.
- 348 IRC5
- 845 RAPID Programming
- 21 AppStudio
