Samples
Aero2000
Someone has set up a station and we can share with the rest.
I refer to
an example of a file .rsstn where can see several robots working.
Thank you very much
I refer to
Thank you very much
If you mean 2 IRB1600 working on a 250k positioner you can find it in my documentsRobotStudioStations and it's a Pack&Go station.
Per Svensson
Consat Engineering0 -
And there is also the Flexload demo station with 4 robotsPer Svensson
- 359 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 30 AppStudio
