power fail restart
carmila
hi,
i have an error "power fail restart". Several days ago , i have read this description, what the error caused by, and the action to do, but when i want to read again, i can't find it. Does anybody can help me to find out this error. What the error caused by, and how to repair it?
thanks before
indah carmila
hi,when you have got the same error, can u note the error number or error explanation? I think you should check alimantation stage(3 phases, outputs of the transformator, Power unit)Only God Can Judge Me0
Hi Cezanne,
Finally, I know the problem that cause my error. It's because I'm stopping the program since the robot connects to the conveyor tracking. I know it, because when I stop the program and turn off the machine, the next day I turn on again the machine, it don't show the same error.by the way, thanks for your reply.
Carmila
carmila2008-12-11 07:28:01indah carmila0
- 359 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 30 AppStudio
