direct connetion through IP - RESOLVED [WebWare SDK]
1. What type of robot/s are you using?
2. Could you please describe what you are trying to accomplish? You can set the current robot alias (defined in Interlink Config) in your code by using the Robot property.For instance: Helper1.Robot = "MyRobot"
______________________________
AndersD38399,5422685185
Anders Dannberg
ABB Automation Technologies
Support Engineer0 -
Well, I want to create the aliases in the Interlink 3 / 4 (if needed) automatically.
Let's say we got daily updates for our robots in the intra-net (IP's). I supply a text-file with a list of the current abb robots to the PC's of our support-team @ production. The people there do not realy know how to set up the interlink propperly.
So I wonder if there is a possibility to use an by-code alias or better add aliases by code permanently. Webware supports DeleteAlias since 3.2 as far as I know.
Robots used: S4, S4C+, IRC5 with Ethernet Option enabled (robots are pingable)
Dev: VB6 with SDK3.2 and Interlink 3 installed
Dest.: PC with VB6-runtimes and installation of our app + Interlink 4
thx in advance
010001110 -
Yes, it is possible to create a new Alias using the SetAliasCfg method of the InterlinkAlias Object. There is also sample code on how to do this in the SDK Help.
Goto Programs -> ABB Industrial IT -> WebWare SDK -> WebWare SDK Help (Interlink Alias Object, Methods)
Anders Dannberg
Support Engineer0 -
discussion moved to ...
010001110
- 5.4K RobotStudio
- 385 UpFeed
- 15 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 405 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 285 IRC5
- 47 OmniCore
- 3 RobotStudio AR Viewer
- 748 RAPID Programming
- 15 Wizard Easy Programming
- 3 Job listings
