flexpendant fault. RS.5.11
hi
after installing RS5.11 i have tried several times to open the flexpendant but all i get is a flexpendabt with a blank screen.
also blank screen when i use the ABB tap in the corner of flexpendant.
What is the problem????
Kent zibrandtsen
Hardi International A/S
Denmark
  • Hi Kent
    Do you get any information on flexpendant when switching to manual mode ?
    Regards
    Knud Erik Lindberg
    Danrobotics
  • Hej Knud
    how is it going :)
    No i dont get any information even though i go from automatic to manuel mode.
    See attachment.
    The screen is just white even though I press the Abb logo in the corner
    Kent,  Hardi international.
    Kent zibrandtsen
    Denmark
  • Fine thanks Cool
    Dos it help to:
    minimize and maximize the flexpendant ?
    Minimize Robotstudio IDE ?
    Regards
    Knud Erik Lindberg
    Danrobotics
  • Also try removing any FlexPendent Application DLLs ...... I've had FP apps compiled for 5.10 cause this(in 5.11), removing them makes the FP work, but then you don't have your FP app.... haven't come up with a fix yet, so I'll be interested in seeing what you folks come up with
    Mike Kegley
  • Rebuilding your apps with RAB 5.11 should fix any compatability problems, or at least report any problems when you attempt to compile it. Make sure to deploy your updated compliance .dll too.
    Russell Drown
  • hi
    It is the flexpendant i RS that is the problem not the pendant at the real station.
    i have no Application DLLs  dll in the station.
    And this seems to be the only problem, eventhoug it is quit a big problem.
    Kent zibrandtsen
    Denmark
  • What RW version are you using?
    Do you get the problem for all systems you have tried?
    In particular, have you tried to use any of the template systems?
    ABB
  • hi Henrik
    I am using RW version 5.08
    Is is only a problem on my own stations.
    I have tried to open a template station and there was no problem.
    Kent zibrandtsen
    Denmark
  • hi
    I have realiced tha my intire mediapool was corupted.
    I have justed replaced it with a copy and there is no problems.
    Kent zibrandtsen
    Denmark
