flexpendant fault. RS.5.11
hi
after installing RS5.11 i have tried several times to open the flexpendant but all i get is a flexpendabt with a blank screen.
also blank screen when i use the ABB tap in the corner of flexpendant.
What is the problem????
Kent zibrandtsen
Hardi International A/S
Denmark
Denmark
Hi KentDo you get any information on flexpendant when switching to manual mode ?Regards
Knud Erik Lindberg
Jorgensen Engineering0 -
Hej Knudhow is it goingNo i dont get any information even though i go from automatic to manuel mode.See attachment.The screen is just white even though I press the Abb logo in the cornerKent, Hardi international.Kent zibrandtsen
Denmark0 -
Fine thanksDos it help to:minimize and maximize the flexpendant ?Minimize Robotstudio IDE ?Regards
Knud Erik Lindberg
Also try removing any FlexPendent Application DLLs ...... I've had FP apps compiled for 5.10 cause this(in 5.11), removing them makes the FP work, but then you don't have your FP app.... haven't come up with a fix yet, so I'll be interested in seeing what you folks come up withMike Kegley0
Rebuilding your apps with RAB 5.11 should fix any compatability problems, or at least report any problems when you attempt to compile it. Make sure to deploy your updated compliance .dll too.Russell Drown0
hiIt is the flexpendant i RS that is the problem not the pendant at the real station.i have no Application DLLs dll in the station.And this seems to be the only problem, eventhoug it is quit a big problem.Kent zibrandtsen
Denmark0 -
What RW version are you using?Do you get the problem for all systems you have tried?In particular, have you tried to use any of the template systems?Henrik Berlin
hi HenrikI am using RW version 5.08Is is only a problem on my own stations.I have tried to open a template station and there was no problem.Kent zibrandtsen
Denmark0 -
hiI have realiced tha my intire mediapool was corupted.I have justed replaced it with a copy and there is no problems.Kent zibrandtsen
Denmark0
- 338 IRC5
- 67 OmniCore
- 832 RAPID Programming
- 14 AppStudio
