problem simulation signal
I have a problem with the signal simulation.
I started the E/A Simulator.
Everytime If I set a new value in the simulation tool coming the messages "examining access authorization".
I don' t the Supervisor password and username, what can I do?
Thank you for your help
Tobias
Solution provider
www.bhv-automation.de
Be sure that you have access level "All" and not "Default" for the signals.
Per Svensson
Consat Engineering0 -
Hello Per,
please make a screen shot, with the settings instruction. Ididn't find the setting tool.Thank youSolution provider
www.bhv-automation.de0 -
Here you go
Per Svensson
Consat Engineering0
- 337 IRC5
- 67 OmniCore
- 831 RAPID Programming
- 14 AppStudio
