Connect a Servo motor to IRC5's devicenet
Does anybody know how to setup a devicenet Servo drive (say a Baldor or SEW) to the IRC5 controller's device net?  Thanks in advance.
  • If you don't know the parameters of the device, you can add a device of the type DN_GENERIC with the correct address and the system will detect and use the correct default settings for your device. You should then use this information to define a new unit type.
    Russell Drown
