How to open 2 windows?
Yu I
How can I open 2 windows like set position window and joint jog window?
I can open only 1 window at the same time.
BR
Yu
There is a limitation in the window handling. The workaround is to proceed as follows:1. Open Set Position window.2. Tear Off3. Close the docked "Set Position" window, i.e. not the floating one.4. Open the Joint Jog window.5. Tear Off6. Close the docked "Joint Jog" windowHenrik Berlin
ABB0
- 338 IRC5
- 67 OmniCore
- 832 RAPID Programming
- 14 AppStudio
