Communication Runtime
PerM
Hi Everyone,
Small question.
I have made a PC-SDK project (5.10). I also made a setup project for this to be used for installation at the PC.
I have also installed the ABB Communication Run-Time separately.
All this works fine, and the application is running.
Now to the question. Is there any way to get the Communication Runtime installation to run from my own created setup project? Maybe before or after.
Can I solve this by importing the communication setup files into my setup project? Where should I in that case put them? Should I use all the or just the .msi and cab file?
Let's see if anyone have some suggestions.
/PerM...
Most installation tools should allow you to call the RCR setup.exe from the main setup project. It really depends on the tool you are using as to how you package it from there. It shouldn't require much work to do so, as you will simply launch the RCR setup and make the user step through it before resuming your application installation.Russell Drown0
