robtarget error [ArcWelding PowerPac]
I assume that you are working with AWPP. It is not clear from your description if the path containing the instructions was opened as the error message suggested?
As for you second question: Did you try to modify the external axis in RS base or AWPP?
Problem 1:The problem is, that in RS window you do not have the correct Wobj open in the top of the screen.
Kent Zibrandtsen
Dept manager robot welding
Kez@hardi-international.com0 -
Try to add an ActUnit instruction to start the external axes, before other motion instructions?
- 363 IRC5
- 81 OmniCore
- 853 RAPID Programming
- 31 AppStudio
