defining robotware release
praveen
hiA?
well when i try to create startion using template,it asks me for browsing Robot ware release to use for system.I am not getting what does it means..which path should i specify?
i tried but not finding folder where i can see robotware etc?
so please tell me how to define robotware release???
praveen
Hi,I guess you are not installed the required Robotware along with the RS.Please check in the system builder whether the RS version and Robotware are shown in the pull down list in the CONTROLLER KEY & ROBOTWARE selection window.Regards,
Nikhil0 -
hi Nikhil..thanks for advice..yeah i ve noticed that i ve not installed RS correctly..i ll do fresh installation..thanks for guidepraveen0
Hi Praveen,it is my pleasure to share the knowledge.Regards,
Nikhil0
- 359 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 30 AppStudio
