Mechanism Modler
I am trying to create a device mechanism, in RS5.11.01 but
not getting the option of Compile Mechanism. following same procedure as
used in RS5.10,
can any one tell me what care should be taken.
thanks.
rajrishiraj
HiI have seen this problem depending on the resolution of your screen. So undock the window and drag i bigger and you will be able to see the Compile button.Per Svensson
Consat Engineering0
- 361 IRC5
- 77 OmniCore
- 852 RAPID Programming
- 30 AppStudio
