RobotStudio 5.11 - transition
I'm trying to create a new cell from backup and i have not been able to download the new system to controller. the controller is not showing up as a virtual controller
Hi,A system is never downloaded to a virtual controller. Proceed as follows1. Create the system using the function "Create from backup".2. Start the system in RS by using the command "New Station" with "Existing system" and point out your new system3. Restore the backup.If you are running RS 5.11.01 and you want to create a station that corresponds to a physical controller, then you can use the "Go Offline" function available in the "Online" tab.Henrik Berlin2008-12-22 08:14:24Henrik Berlin
ABB0
- 303 PowerPacs
- 353 IRC5
- 849 RAPID Programming
- 24 AppStudio
