WebWare compatibility with S4C [WebWare Server]
Hello.
I wonder if I can use WebWare and WebWare SDK to interact with S4C controllers? Does this compatibility depend on WW or RW versions? If I got it well: the only indispensable RW option is PC Interface - am I right?
If anyone can help me - thanks.
Wojtek_PL
Wojciech Wlodarski
PLABB
  • Hello jawojtek,
    Yes.
    BaseWare version.
    In S4C the required option is named [FactoryWare Interface] and you probably need to upgrade the memory as well.
    Attached you can find a table for S4, S4C and S4C+ controllers
