Load form from signal change
I am getting frustrated.  I need to load a new form when a signal changes in the IRC5.  I can not use the SignalBindingSource because I have to bind a visible control to it in order to see it change.  And I can not get the standard signals to show my form.  Here is a code example.
private void _sigSystemState_Changed(object sender, ABB.Robotics.Controllers.IOSystemDomain.SignalChangedEventArgs e)
//Update the GUI if the signal GI_001 changes in the controller
CalibrationView2 _CalibrationView2 = new CalibrationView2();
_CalibrationView2.ShowMe(
this);
private void button1_Click(object sender, EventArgs e)
_CalibrationView2.ShowMe(this);
The button example works fine but the SignalBindingSouces change event is on another thread?  Exact error: "Controls created on one thread cannot be parented to a control on a different thread."
So how do I have a simple signal show a new view/form?
Shane
  • Hi Shane,
    I tend to over-explained the stuff ... please let me know if I am goind to much in detail, I will do my best in next posts :). So here it comes
    Only the UI threads are allow to execute code that will modify the user interface.
    Inside a Teach Pendant application, there is only one UI thread running at all time. All the events coming for the IRC5 (either by the BindingSource or a Changed event of a RapidData or Signal) comes in a different thread. Hence, what we need to do is to call the UI thread from your executing thread. Here it comes some sample code:
       void MySignal_Changed(object sender, SignalChangedEventArgs e)<?: prefix = o ns = "urn:schemas-microsoft-com:office:office" />
                // We are running in a non-ui thread, so it is not allowed to make changes in the user interface. Lets invoke the UI thread
                // In order to invoke the UI thread, we need to use a control that was created in the UI thread.
                // In most of the cases, the form in which you are runnning was created in the UI tread, so lets use that one.
                // We will assume that 'this' makes reference to the form
                this.Invoke(new SignalChangedEventHandler(MySignal_Changed_UI), sender, e);
            void MySignal_Changed_UI(object sender, SignalChangedEventArgs e)
                // This code will be running in the UI thread as long as it comes from an invoke
                // Here, you can open your view
    In your case, the method _CalibrationView2.ShowMe(this) is tryting to create and display a Form.  It does not work in the method "_sigSystemState_Changed" because this in called by the SignalBindingSource; the other one because a method that is called for a Click event, it is executed inside a UI thread already (the event is UI driven as such).
    Hope this helps to explain the behaviour.
    Saludos ... Carlos
    Carlos Martinez
    ABB
  • Carlos,
    That is exactly what I needed!  Thanks for taking the time and effort to, as in your words, over-explain stuff.  It really is appreciated.
    I will try this this morning,
    Shane
