Load form from signal change
I am getting frustrated. I need to load a new form when a signal changes in the IRC5. I can not use the SignalBindingSource because I have to bind a visible control to it in order to see it change. And I can not get the standard signals to show my form. Here is a code example.
private void _sigSystemState_Changed(object sender, ABB.Robotics.Controllers.IOSystemDomain.SignalChangedEventArgs e)
//Update the GUI if the signal GI_001 changes in the controller
CalibrationView2 _CalibrationView2 = new CalibrationView2();
_CalibrationView2.ShowMe(this);
private void button1_Click(object sender, EventArgs e)
The button example works fine but the SignalBindingSouces change event is on another thread? Exact error: "Controls created on one thread cannot be parented to a control on a different thread."
Hi Shane,I tend to over-explained the stuff ... please let me know if I am goind to much in detail, I will do my best in next posts
. So here it comesOnly the UI threads are allow to execute code that will modify the user interface.Inside a Teach Pendant application, there is only one UI thread running at all time. All the events coming for the IRC5 (either by the BindingSource or a Changed event of a RapidData or Signal) comes in a different thread. Hence, what we need to do is to call the UI thread from your executing thread. Here it comes some sample code:In your case, the method _CalibrationView2.ShowMe(this) is tryting to create and display a Form. It does not work in the method "_sigSystemState_Changed" because this in called by the SignalBindingSource; the other one because a method that is called for a Click event, it is executed inside a UI thread already (the event is UI driven as such).void MySignal_Changed(object sender, SignalChangedEventArgs e)<?: prefix = o ns = "urn:schemas-microsoft-com:office:office" />
// We are running in a non-ui thread, so it is not allowed to make changes in the user interface. Lets invoke the UI thread
// In order to invoke the UI thread, we need to use a control that was created in the UI thread.
// In most of the cases, the form in which you are runnning was created in the UI tread, so lets use that one.
// We will assume that 'this' makes reference to the form
this.Invoke(new SignalChangedEventHandler(MySignal_Changed_UI), sender, e);
void MySignal_Changed_UI(object sender, SignalChangedEventArgs e)
// This code will be running in the UI thread as long as it comes from an invoke
// Here, you can open your view
Hope this helps to explain the behaviour.
Saludos ... CarlosCarlos Martinez
Carlos,
That is exactly what I needed! Thanks for taking the time and effort to, as in your words, over-explain stuff. It really is appreciated.I will try this this morning,Shane0
