URGEND! Problems with InterLINK (v3,v4) [WebWare SDK]
Hi there!
We got serious problems with the connection to our robots. Due to our WindowsXP-rollout we changed our os from WinNT4(SP6) to WinXP-Pro(corporate modified version).
We got the following situation:
- we have some robots connected to our local area network
- we can ping the robots successfully
- we can connect to the robots with a laptop still using WinNT4
- we cannot connect with any pc using WinXP
Anyone a idea why? What in detail is needed for InterLINK?
The errors also occur, if we make a seperate network (connect directly via an cross-cable to the robot and using 192.168.0.99 for the pc and 192.168.0.50 for the robot)
We need an urgend fix for our problem, our comming production-lines depend on the communication.
thanx in advance
Mathias Richter
DaimlerChrysler AG
Development/Robotics
Germany
01000111
Are you running Service Pack 2 on your Windows XP machines?
______________________________
Anders Dannberg
ABB Automation Technologies
Support Engineer0 -
we are running SP1--------
010001110 -
just talked to mr. kevin behnisch. We are trying to solve the problem.
thx
010001110
- 303 PowerPacs
- 353 IRC5
- 850 RAPID Programming
- 25 AppStudio
