Command Bar
sunil sabut2009-01-22 06:00:34
Sunil Sabut
India Corporate Research
ABB - India
  • Hi Sunil,
    Iniside ScreenMaker, the CommandBar is treated as a Menu control. This means that it could only be located at the bottom of the Screen (similar to a Menu inside a Form, which is always located at the top of the Screen). The workaround will be to add the CommanBar inside a Panel, and just re-locate the Panel.
    PD. We might need to hide some of the layout properties to avoid these confusions.
    BR/Carlos
    Carlos Martinez
    ABB
