Run routine button
GaryRice
in ScreenMaker
I have built a screen that has a run routine button that is assigned to run a home routine, When i deploy it to the flexpendant it appears greyed out. Any ideas?
GARY
Hi GARY.
This button will be enabled if:- There is a valid RAPID program with no errors and a Program Pointer- RAPID program is not running- The system must be in Manual Mode <- this is an option, so you could allow this button in Auto by changing the property called AllowInAuto to TRUE.This buttons relies on the module ScreenMaker.SYS, just please make sure you have it.BR/CarlosCarlos Martinez
Hi Carlos,Thanks! do you know where i can get this module from?RegardsGARY0
Hi Gary,you can find these files in the folder:C:Program FilesABB Industrial ITRobotics ITMediapoolRobotWare_5.XX.optionsgtpusdkYou have to load both cfg files, and copy the screenmaker.sys file in the home folder ( I believe).CarlosCarlos Martinez
Thanks0
- 359 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 30 AppStudio
