How to read NUM i VSTA
Hi.
I need to read sum num from my rapid program in vsta to create some boxes.
No problem with creating boxes but can't found out how to read NUM.
An example would be great.
BR Klaus
Best Regards
Klaus Soenderhegn
www.cadalysator.dk
  • Hi
    You need to use RAB to read data from the controller even in RS
    Per Svensson
    Consat Engineering
  • Hi Per.
    I can read and write to IO from VSTA soo it should be possible to also read and write to rapid data from VSTA.
    BR Klaus
    Best Regards
    Klaus Soenderhegn
    www.cadalysator.dk
