No robot displayed
Some of the robots I work with are displayed in QuickTeach, but for some reason when I load a 2400, I get a floor with no robot. The program will still run on the virtual teach pendant, but the motion clock does not run. I also cannot see the 6600's, but 140, 4400, 640's are all fine.
How can I get the robot to be correctly displayed?
I am using QuickTeach 5.0
Thanks in advance,
Alistair.
Hello Gizmo,
Is it possible that the robot models you mention have been moved in the library, i.e. are the rlb-files located correctly in your file structure?
Your problem might be that QuickTeach cannot find the rlb-files and therefore can't display them either.
Please look in your explorer and make sure all robot models are there.
Best regards
/Ulrika Mor?n
Thanks for that. I now have .RLB files and the supporting directories for the 2400 and 6600 robots. However when I start QT5.0 I still don't get a robot displayed.
When I start at 640 for example, I see the QuickTeach 5.0 Virtual Controller splash screen, but when I setup a 6600 for example, I don't get the Virtual Controller splash screen, but I do still get the ABB Virtual Controller running icon (green) in the system tray.
Thanks in advance!
- 367 IRC5
- 858 RAPID Programming
